Mario77746
I don't know how it happened but my headlight is set about 30 degrees off. This f'n thing got me so pissed earlier today I had to just walk away:angry: . I took out both screws and can not turn it at all. I shot some carb cleaner around the ring to clean out all of the dirt. One guy told me to take my heat gun to the outside of the headlight. Do you think this will hurt the chrome?
Any other tricks to pop this out? If not, I'm going to have to drill a hole and tap it out.
Thanks.
Thanks.
. Nothing worked so.......I took a 5/64 drill bit and drilled a small hole in the center of the top of the ring. You can't see it unless your looking for it. I then took a punch and tapped the thing loose. Then I wrapped tape, sticky side OUT around my thumbs and took this f'n ring off.
. I cleaned it up and had to use the nail to tap it back into place. I put the locking screw in place and wouldn't you know it, the threads are stripped. I ended up putting it in the 2nd hole. We'll see if it holds....
