BlueBeast K9
On my 2006 K9, I have replace the OEM bulb (60/55W) candlepower 4720 with a LED bulb (Headwinds) that uses less watts and has the bright white light. After about 20 minutes of riding, the high beam comes on and will not default back to low beam. Could this be because of the more heat a LED produces compared to OEM and this confuses the EHC? I put on OEM bulb back in and the problem goes away. I did the same swap on my 2006 Mastiff and had no problems. Has anyone else done a LED upgrade to their Big Dog?
