roedog
Turned on the key and noticed the blue led light was on, which is for the brights on the headlight. But I did not have the brights turned on and noticed the headlight was not working. So I tapped on the headlight and puff it started working. Then it happened again after I shut off the bike for about an hour or so. Tapped on it again and it started working and worked the rest of the night ok.
Not sure if the headlight connector has bad connection or bulb is going out?
Has anyone experiened this on an 03 Mastiff?
Thanks,
Sean
Thanks,
Sean
