Headlamp removal Q?
Chong
U-235
So , I have been attempting to change my headlamp .
I have read about it .
Problem , trim ring will not turn .
Set screws , First off there only one outer and one inner . Both spots are missing the second one, empty holes .
Removed front set screw and can't get ring to unscrew at all with rubber gloves I did spray some wd -40 around the seam, didn't look too promising to help but I did .
Well that's it , no turn / no unthread .
I have a rubber wheel meant for taking graphics off with a drill. Pretty much an gum eraser material, smells same when using . So been thinking about using it on the ring to get it to budge ?
Thanks .
Jwooky
Try cleaning the ring with alcohol real good to get all the grease/WD 40 off it if you haven’t already.
I will stand behind the headlight, facing the same direction as the light is shining with both hands and rubber gloves pull outward while rotating.
absolute worst case drill a hole it the ring and hammer it out with a drift and replace the ring.
Chong
U-235
I will try these things in this order .
Unless other Ideas come along .
Yeah I have it cleaned.
A. Two hands with gloves while pulling forwards .
B. Like 4 wraps with masking tape on the bit of ring exposed. One layer electrical tape on housing . Hoping to get more pressure on ring then the housing . And use fabric strap wrench.
C. Eraser whell .
D. Drill hole and drift pin. .
C. Eraser whell .
Missed one.....remove and replace with an Adjure bucket. No more stuck trim rings. Worked for me ....jmo.
Chong
U-235
Thanks !
