Headlamp assembly missing parts?
toodie
My headlight was spinning around in the housing when I first got the bike this year brand new. This has happened twice and the service shop fixed/adjusted at my 500 & 3000 service. Today I noticed the lamp very loose again so I pulled it apart myself. I would have taken it to the service center but it is an hour away. According to the service manual looks like I am missing the 2 O-rings in front of the lamp (21) and the back rubber ring (26). Does anyone know if these are truly missing for the 08 pitbull I assume so but not sure? Also I noticed some threads talking about a tool for specifically removing the threaded ring (22) is someone on BDB still selling that tool? I was able to remove pretty easily but getting that ring back in is not happening:bang: and I don't want to damage anything trying to Rube Goldberg it.
The shop seems to get it tightened up but inevitably it comes loose. Could the missing o-rings have anything to do with the headlight coming loose?:confused:
Any who your input, as always, is much appreciated.
Brew
Nope those seals are to keep moisture out. What prevents the rings from loosening is the allen head set screw #28 in the bottom of the bucket. You should not have to mess with #29 no reason too!
toodie
What's appears to be happening though is that the back ring that is held by #29 is coming loose as well. I can reset the back threaded ring but just can't tighten down the front threaded ring (#22) need a tool. The #28 set screw is for the bezel. It's odd that all of the rubber is missing :rant:
Brew
Some members use a phillips screw driver and a mallet to tighten and loosen that ring (#22). Just don't whack it too hard or you will end up tweeking the assembly. There is a special tool, but good luck in getting one. I had to take my bucket to the local service center and they took it off for me. I ended up just buying an adure light assy for my bike. No more threaded rings. By the way my assembly didn't have the #21 o-rings either and if you look at the tread below, it looks like Gas Man didn't either...
http://www.bigdogbiker.com/forums/how/12-how-replace-your-headlight.html
armad
They must have run out of rubber parts when assembling the 08's. Mine was the same way. Missing the o-rings and the rubber gasket. I ended up making my own from plastic. It works, but the rubber would be better. Good luck trying to get them from BDM.
