DO NOT install a 90/100 watt in place of the 55/65 watt stock bulb!I just had to change my headlight bulb it blowed on bright. I installed a High Output and oem Halogen H4, 90/100 bulb in it. Should I be all right with this or not. If not would you explain why. Thanks:
Funny I have a 60-80W light in mine for over a year and I have no problems?That stock socket can't even handle the current of the stock bulb without melting. Not to mention the little tiny wiring and long ass ground wire ran all the way back to the EHC that will melt down.
I ordered one of these ceramic H4 sockets to replace my stock one:
H4 Headlight Bulb Socket Connector Xenon Ceramic - eBay
Come on Jake, I have 60,000 miles now on my 05 Chopper with the stock bulb setup and ChopperJeff has about the same and we haven't had issues as well as thousands of others.That stock socket can't even handle the current of the stock bulb without melting. Not to mention the little tiny wiring and long ass ground wire ran all the way back to the EHC that will melt down.
Then you guys are lucky because after 15k miles, I took my headlight apart and the connector crumbled in my hand and I just ran a stock spec bulb, nothing 'high output'.Come on Jake, I have 60,000 miles now on my 05 Chopper with the stock bulb setup and ChopperJeff has about the same and we haven't had issues as well as thousands of others.
:flag:
Before the HID kit, with the stock bulb in the bikes, I had 3 headlight sockets melt down between my two bikes. Come on Raywood... everyone knows it is a recall for all BDM bikes for the headlight connector, not just me blaming something BDM did because I sell HID kits!!! It is a big problem for BDM.Come on Jake, I have 60,000 miles now on my 05 Chopper with the stock bulb setup and ChopperJeff has about the same and we haven't had issues as well as thousands of others.
:flag:
Passed?, Passed by who or whom?The wiring will handle the current. It is MIL spec wire, 7.5A is pushing the connector pin limits. If there is any complaint I can make about the wire size it is not that it will not handle the current, it is that it is small enough area that it does not pull any heat away from the connector and then the connector starts to melt and takes the terminal with it. There is a service bulletin out there for a headlight wiring update. The updat added about 6" of large gauge wire to the headlight side of the harness. It does not offer much in the way of higher current ratings especially since the wiring from there back to the EHC is still the smaller gauge. Detailed testing showed it was the heat sinking the larger wires provided that helped the melting connector issue. It was tested and "passed" up to an 80W bulb.
That ceramic connector looks cool. Couldn't find that one when were were testing, did burn up some so called "Hi heat" connectors pretty quick.
wow bad carma :bang: my high beam went out yesterday :angry: I guess from all the good stuff written about the HID kits I guess I'll be ordering one of these to give it a try:2thumbs:Funny I have a 60-80W light in mine for over a year and I have no problems?
T.Byrd,Guillaume, I don't think they melt down, but get brittle with age after being hot for so long.Then they just fall apart. or thats what I understand them to say.
