Adjure makes a nice one for sure. My OG bucket was a PIA. The nylon rod makes it super easy to open up too.Here is the URL http://www.adjureinc.com/motorcycle1.html
That is where I found my bucket..
Hello, did you have to rig anything behind the new light, or do you think the stock bezel ring would hold the light in place? I plan to order the light like you have instead of the bulb upgrade since my stock lens is dingy. I still have the bezel ring. Thanks ahead if you reply. Looks great btw.
Yes you can use the stock holding bezel ring and you dont have to do anything but plug it up no modifications to the existing wiringHello, did you have to rig anything behind the new light, or do you think the stock bezel ring would hold the light in place? I plan to order the light like you have instead of the bulb upgrade since my stock lens is dingy. I still have the bezel ring. Thanks ahead if you reply. Looks great btw.
Thanks I am ordering it now. I tried unscrewing the bezel and seen the post using 3m tape. I have a feeling someone used lock tight. I will try my strap wrench.Yes you can use the stock holding bezel ring and you dont have to do anything but plug it up no modifications to the existing wiring
