Has anyone lengthened their K-9 forks
Jersey Big Mike
100K mile club
and went an extra 2 or 3 inches longer, nothing drastic.
I'd love a little more length ( i know I won't get much with this) and was wondering if it doable,
I found a site that makes parts to extend 41mm forks by 2 or 3 inches without major work!
Interested in peoples thoughts on the idea -- Woiuld end up with more of an old school look where the bottom of the frame lifts up a little bit in the front from what I can see.
It's pretty cheap to do $120 of parts.
Ok -- let me have, I'm ready.
Jersey James
Jersey James
Hello. From what you are saying, sounds like are considering using "Slugs". Not really recommended. A better plan would be using ONE PIECE extended fork tubes. Much stronger and safer...
Jersey James
Jersey James
Jersey Big Mike. What you pictured are what we called "Slugs". Back in the late 60s early 70s. They were a cheaper method of extending your front end. Some/most considered them somewhat safe, if the joint was made in between the top and lower triple tree. Back then, for another hundred bucks you could order one piece front fork tubes, from guys like "Forks by Frank" super strong, great looking. Not much harder to change out. Hope this helps.
