rfkutschman
I knew it'd happen sooner or later . . . was just hoping for much later. '07 K9 with approx 2250 mi. Never had any problems. Started it this AM - normal, no problem. Died after about 30 seconds - figured I'd just let it bog down while cold. Tried to restart. Nothing.
Turn the key, lights come on and speedo goes through it's normal start up. EHC lights (blinking light panel) shows only the number 3 (orange solid) and number 4 (blinking green) are on - numbered from forward and inside (forward most inside light is number 1 and right next to it is number 2.
Hit the start button and only get the click of the compression releases (checked by placing finger on the plastic bubbles as described in another thread). Nothing else. At the same time, the headlamp gets dim. I also now have a blinking red light in the #12 position.
No cranking, no nothing.
Battery tests out at H-D shop at 12.8 volts. Terminals clean. Don't know much else.
Starter? Relay of some sort?
Thanks all. Wanted to ride this weekend. Looks like that may not happen!
rich :down:
rich :down:
