grumpys exhaust
sics6
Is grumpys exhaust outta business? Cause I keep getting the same voicemail from there. But the problem is I recently bought a twisted sister exhaust from someone online brand new but the trans mount bracket doesn't line up or work at all. I mean we spent like an hour trying to see if it will work the design is totally off. Does anyone have or make the proper bracket? The exhaust is mounted to the heads and the bolt has tied the two pipes together, but the bracket for the trans mount won't work.IMG_0648.jpg
tommy666
Thanks! I had one made for the exhaust that I'm using. I even used the stock vibration mount that came on my stock pipes. Good luck!
