Gas leak from bowl vent
Svahna
Hi guys I´m going nuts....Need your help deperately.
Yesterday I got the bike street legal :whoop:
in order to get it so I had to replace exhaust and carb temporarily
do to the noise :job:
And now when I´m done I put the original stuff on again and the carb leaks
fuel from the bowl vent ( below the choke ). WTF???
Please HEEEEELPPP now when I finally can ride my sweet bike
I cant!! :rant: :angry:
Thanks>Jimmy
Pull the bolw and clean it out. Its pretty easy to do
Thanks, will try.
Can it be done while carb is on the bike?
Anything to whatch out for?
You may have to pull the aircleaner and back plate depending on what you have. Drain the bowl by removing the bolt in the bottom then remove the 4 screws and be careful not to loose the little blue oring that goes over the nozzle. Clean it out with some cleaner and put it back together.
Svahna
Great news!!
Problem solved. Turned out the needle had gotten lose.
I just put it back in place and put the shit together again.
guess whom is going to be riding all day tomorrow?? :whoop::whoop:
Thanks Guys!!
