armad
I did some searching and found the paint bubbling issue is quite common on the Big Dogs. Haven't found out how to actually cure the problem. My bike has the Landmark paint saver and gas cap. Yesterday it was hot here and went for a ride. When I got back the cap wouldn't unscrew, it would just spin the cap. It had been leaking when I was riding and wanted to see if the venting was full of gas. The tank was only about half full. I ended up putting a bag of ice on top of the cap and let it sit a while. It screwed right out after a half hour of the ice application. During my search I found that the plastic screw part expands because it absorbs some gasoline. This sucks for sure as if I need gas, don't want to be sitting waiting for the screw portion to shrink down. I filed it some and applied some grease and will see what happens today. The paint around the paint saver has been bubbling for some time now. I took some alcohol and cleaned around the edge of the paint saver and applied some clear fingernail polish. I will need to have the tank repainted though as the paint is totally screwed up. Has anyone actually CURED
this problem for good? I have a couple other bikes and have never had a problem with leaks, venting or paint lifting.
