Firestream
Need some help guys, have an 05 chopper with on-going clutch issues that dealer has been unable to solve. So I installed Bandit assembly along with their new carrier, bearing and new flanged hub from BDM. One of the updates the dealer performed was the shim behind the carrier and I left in place with Bandit install, checked alignment and clearance for new carrier and everything looked good. Started off with two shims in each spring cup as directed by Bandit and used their suggested oil (Spectro golden 80) and pre-soaked the clutch friction discs. Everything went together fine and all adjustments checked with a dial indicator. I set adjustment on clutch rod (well lubed) and adjusted clutch lever to spec. Time to test ride, clutch slipping... I decided to order the updated clutch rod and installed yesterday along with another shim. Went thought the adjustment procedure and, still slipping. Ended up with more shims to equal 404 pounds of pressure. Still slipping along with some vibration. Backed shims down to two each cup, tried several clutch rod positions (1/4 turn back, 1/2 turn back, 3/4 turn back and 1 full turn). still slipping... The good news is, no shavings in primary oil, so I know the carrier is not shifting around, but the slipping is really driving me nuts. Reading the manual, if clutch not adjusted correctly it will slip. Followed their procedure to the letter. Any suggestions would be appreciated...
