front wheel spacer
stig
cycomutha
put new forks on my 05 pitbull (BDM had a wicked sale!), when i went to put the wheel back on, the axle wouldnt go through the wheel. i find out that the spacer in between the bearings moves around . is this normal? i managed to get it through, but now im wondering if somethings wrong
No as long as there isnt too much space. It acts as a bearing spacer to keep everything running smooth. If your ride has been good for this long then its not likely anything is wrong.
Moespeeds
It's normal for them to move if you jostle the wheel enough with no axle in there. Make sure the wheel spins free when you remount it.
stig
cycomutha
:iagree: Also make sure that the wheel bearings are flush with the wheel hub.
thanks all . everything seems well :up:
