awg Guru Sep 25, 2023 #1 I am about to install a new front tire on my Mastiff. Would like to change the wheel bearings while I'm in there. How do they come out?
41bigdawg Let the Big Dawg eat ! Sep 26, 2023 #2 You will need an wheel bearing removal/installation tool, I use the one from maXpeedingrods, makes the job pretty easy. Amazon.com
awg Guru Sep 26, 2023 #3 OK. Thanks for this info. I was hoping after removing the seal they would just come out. Well I was wrong.
HMAN I just like my Freedom Supporting Member Sep 26, 2023 #4 You can do it the hard way or the easy way as Robert suggested. Best way is to use the bearing puller. They cheap anyways.
HMAN I just like my Freedom Supporting Member Sep 26, 2023 #6 awg said: Has anyone used the Tusk bearing removal tool? Click to expand... I snagged the Orion. Works well. Ima be using it again soon as I need a new rear tire.
Mickmorris Well Known Member Supporting Member Oct 1, 2023 #7 HMAN said: I snagged the Orion. Works well. Ima be using it again soon as I need a new rear tire. View attachment 119779 Click to expand...
awg Guru Oct 1, 2023 #8 Alot to choose from for sure. Leaning towards the Tusk one. The video seems pretty easy to do. I am sure they all pretty much do the same thing.
