Front brake switch set secrew
Little-Boo
Does anyone have that tiny set screw that holds the front brake magnetic switch in the housing. I have one but the area where the Allen wrench goes is stripped and I want to replace it while the assembly is apart. The manual says its a 1/4-20 x 1/4 but looks smaller to me. I measured it and its 1/8 -20 x 1/8 so that is what I am looking for.
Carlos :oldsmile:
FrankBDPS
If I had one I would sure send it to you. You have always been generous with the guys on here. It seems like it would be either a #10/32 which is fine thread or a 10/24 which is course thread. A hardware store should have something. Good luck!
Little-Boo
Thanks FrankBDPS, I found the right size by using a tap from the Tap set that I have. The size is 18-8 (Stainless Steel), 4-40 X 1/8th. They only come in packages of 100 or more for $4.72. So now I'll have about 99 to give away. :oldlaugh: :old2:
Carlos :whoop:
