Found the problem
rockerchopper
Since the bike would turn over and everything else seemed to be OK I pullrd one of the plugs put my finger over hole and cranked the bike......no compression..zilch...nada. Guess I will transported to the shop. Anyone intersted in an 05 RIDGEBACK...cheap... as is.
Compression?
When you said it spins over sort of easy on the other thread, that was [my] FIRST [clue] to asked was... Where are we when we want to shoot the amigo right in the head is take a compression test to the head so that "IS FLATHEF''INN ELIMINATEDo The WORK" and that doubt is cleared from the Bandits Booty Table!
Make sense? :up:
Singed,
Cleans UP your Tail Chasing Table Manors.
Brew
So here's the question? How much compression would you have if the compression relief was stuck in open? Is this possible? Have you checked that? Just wondering and trying to save you money if thats what it could be.
pauly
You rode the bike one day and it wouldn't start the next - no compression.
This tells me that it should not be anything major unless you not telling us something.
It could be what Rob is saying.
Paul.
BadDawg Bill
Paul.
2X you don't good compression one day and none the next unless you blew out the rings/valves etc. Check the compression releases like Rob said. Good luck.
