I have a 208 Mastiff. I removed the triple trees and completly disassembled them. Sent them in to get chromed at Meclec in Calfornia.. I have received them back from Meclec. I reinstalled the trees per the Big Dog workshop manual. The problem is that I cannot get the fork tubes to line back up with the upper tree. I slide them up thru the lower tree. But once I get them up to the top tree they will not line up with the holes. Both fork tubes are about 5/8 of a hole off. I have assembled the trees/forks on the bench and everything lines up ok. But when I assemble them on the bike with the steering neck bearings installed, the tubes will not line up. Any help or suggestions would be appreciated. Thanks
