Fork Seals
phatchopper300
I just wanta ride
Is this due to a leak also This is all that comes out. I can't seem to get the cones loose either tired a strap wrench with out any luck. Should I heat it up a little. Sorry for jacking the thread.
erldawg
A little will be normal. What happens when you wipe them down? However when your riding down the road and you see oil on the forks starting to running up the forks from the wind then the seals are definitely leaking.
erldawg
OK I'm done with reinstalling another set of new seals. It took me 2.5 hrs start to finish which includes cleanup. Hopefully it will not leak this time....:rant:
Cannot test drive, humidity is falling in the form of rain. :eek:
phatchopper300
I just wanta ride
OK thanks for the post and I have not seen it ride up the fork while ridding and have been keepint and eye on it. I think my problem is that i can't get the cones off and all the oil and smug is building up in the cone.
erldawg
I'd try the strap wrench again and heat it up with a hair dryer. Mine actually came right off just turning by hand with a pair of rubber gloves on.
phatchopper300
I just wanta ride
Yea I tried rubber gloves and no good. The strap wrench was a rubber strap and not leather- I will try a leather and heat gun and go from there. Thanks erldawg
Dakotabos
Whats the HD part #? I need to order a set. Riding to work today oil started comming up my fork:bang:
sorry for a 2004 chopper
alphadog
I had my fork seals and bushings replaced this past fall. Mine leak the same as phatchopper300's. I wipe em off and they look the same after next ride. They did that before I replaced em as I recall. Next year I will have to replace the upper legs. Anyone go longer on the upper legs?
erldawg
I picked mine up from a local repair / parts place. If you drop by the HArley dealer just ask for a 41mm set of seals and bushings. I'd replace both while you have the forks appart.
nine lives
When installing the new fork seals, did you guys cover the bush holder (groove in the slider with sharp edge) with a piece of plastic and oil it before installing the wiper and seals? If you don't cover this sharp edge with plastic, the bush holder will damage the seal and cause the seal to leak.
Uh...just looking at my post on the fork seals. Doing it the way I stated is for inverted forks. I had just repaced the seals on two sets of inverted forks so I was still thinking along those lines:bang: Sometimes helps to be awake when you post.:spank:
phatchopper300
I just wanta ride
Update: Took commerical dryer and heated them up and using strap wrench they finially broke loose. I had to use a rubber hammer also. Pain in the ass but they are loose now clean up the inside of the cones. Thanks for the sugg. it worked!! :cheers:
