fork oil
knothead
10 ounces in each leg...factory used 30 weight oil...if you want a softer ride some use 20 weight oil...I prefer 30 weight.
Whatever you use I would get a cheap bottle somewhere that has ounce marks on it and put your oil in that so you know exactly what you pour in each fork leg.
I would use either PJ1 or belray fork oil
NOTE: All models came factory with 30 weight fork oil with the EXCEPTION of pitbull models which used 10 weight oil.
You actually need to change your fork oil every 5000 to 10,000 miles...fork legs are aluminum and sweat so moisture gets in that oil pretty fast. Plus the oil gets pretty warm just by sun light and not to mention working them up and down.
