Vented I believe. It has a tiny hole in the center of the bottom of the cap and one on out side between the gears.I have those on my tanks. Did you get a vented one or a solid one?
Yours appears to sit closer to the tank then mine, which o ring did u use? Per the instructions I used the one that is thicker and designed for the 96-up Harley smooth top tanks
Thats the one I used alsoYours appears to sit closer to the tank then mine, which o ring did u use? Per the instructions I used the one that is thicker and designed for the 96-up Harley smooth top tanks
Thats the one I used also![]()
There's a plastic key fob to open it...too much work for me and I would be worried about dropping it an losing it in say somewhere close to nowhere. (West Texas, New Mexico come to mind)What all do you have to do to change it? I really like the looks of that one.
That's why you get an extra key lol one for the key chain and one for the tool bag.There's a plastic key fob to open it...too much work for me and I would be worried about dropping it an losing it in say somewhere close to nowhere. (West Texas, New Mexico come to mind)
Not super conducive for a dog that wanders far from home in my opinion.
Nothing other than the cap. Unthread old cap, thread in new two piece cap. Then put the cap key on the key chain. I got mine through a local motorcycle part shop for $60 they can be had online for around the same or a few dollars less.
