Splitlog
Ok, a lot of fluid is coming out of my transmission vent tube only when driving.
1. it just started and i have not changed transmission fluid since early last
spring. leak just started soooo no I did not over fill it.
2. could it be primary fluid leaking into transmission causing it to be overfilled
that way.
3. could it have a internal transmission problem causing this.
front of rear fender is soaked lower frame is soaked. I first thought it was the
primary fluid leaking around starter. Inspected and its clean around starter.
I pulled vent tube off and blew through the tube and fluid came out. same smell and look as what is all over.
Thanks in advance.
Curtis that open primary is looking better all the time.
oh I have right at 14,000 miles and transmission has never been out.
that way.
Thanks in advance.
