Extending the brake pedal out to the right!
tommy666
Howdy,
Question, I've done some adjustments and need one more! I put the S&S dual induction system on my bike along with the Rivco Products Hi-Way pegs along with their 3" extensions. My foot controls also have the 2.5" forward extensions. I need my brake pedal to come out at least another 2-3 inches so I can see it. Any idea's? Talk to me!
Thanks!
Tommy
Black Rider
Got any pics of the Rivco bars? As for moving the brake out. Extended cleavis may do it. I bought some off eBay. Have not mounted yet
now, doesn't the bagger have floor boards on it? seems to me like the only logical thing to do would be to find a machine shop that could do an extension block out of billet and then come up with a way of extending the boards out to match. take caution you don't get it out so far that it interferes with how far you can lean the bike.
Little-Boo
Go here
Bolt Depot - Nuts and Bolts, Screws and Fasteners online
Get you a set of Spacers grade 2 Chrome, or aluminum 1 inch long or two inches long. I think I got the 5/16 ID with 9/16 OD or the 5/8th OD I forgot, but I can check when I get home. I had the same problem and that took care of it. Cheap.
If you have the stock foot pegs you will need the Clevis extension and I have a new set that I got from BDM that I will take $75.00 for they cost $119 new and mine are new. You will still need to extend the toe peg and brake peg and that is where Bolt Depot come in. I can take a pic for you but that will be Friday when I get home. I will also be able to tell you exactly what to get from bolt depot screws and all.
Carlos
RubWhore
Asshole Extraordinaire
Get you a set of the extended peg adapters they move the pegs out 2and half inches on both sides
Little-Boo
Howdy,
Thanks!
Tommy
Here is what I have, pictures are not all that great, but you get the idea
Here is what you will need from Bolt Depot
Item 13713 ( 2 inch long spacer 1 inch OD) cat $9.24
Item 13684 ( 1 one inch long spacers 1/2 inch OD) those go inside the big one becasue the hold is big. Cost is $2.24 each
Item # 5556 (1 Stainless Steel Bolt 1/4 X 20 X 3 1/2 inches long) Cost $1.17
The Last Picture are the clevis extensions I mentioned before. The will only fit stock foot pegs, cost is $119 at BDM I will let them go for $75. shipped if you are interested.
Anything else you need to know about this let me know
Carlos
