T Tony Rhodes New Member Jun 13, 2013 #1 Why is the front pipe starting to discolor from the exhaust port down about 6 to 8". The back pipe has no discoloration!! I have a S&S 107
KaptinAmerika Guru Jun 13, 2013 #2 Have you pulled the plugs and looked at them? Pull the plugs and post pics here
B bigdogtech01 Well-Known Member Jun 13, 2013 #3 Is this something that just started? If so, it might have a front cyl intake leak at Intake manifold seal.
KaptinAmerika Guru Jun 13, 2013 #5 bdtech is in there Run the motor and spray a little WD40 around the intake manifold If you have a leak the motor will miss and sputter a little
