Exhaust Bracket
R
raider117
Guest
Looking for a chrome exhaust bracket for V&H Big Radius pipes. Does anyone know where I might be able to get one?
aspen874
I would take Curtis up on his offer, by the time you order one from V&H, take it somewhere to get it chromed, you will have spent more plus all the aggravation.
Angry Dog
I have a chromed bracket for V&H 2 in 2 that come off a 08 K9. PM me if interested and I will shoot you a couple of pics to make sure it is what your looking for.:flag:
I wouldn't fab anything out of stainless that has to be welded together and will be subjected to heat and vibration, unless I paid someone who does nothing but stainless welding and then had it xrayed.
Because it will fail especially on exhaust.
If you did everything you needed to with a stainless bracket to insure non-failure you would be ten times what a steel chrome unit is going to cost.
Juz sayin
BadBrad
2005 Pitbull
I guess the exhaust bracket for a K9 must be way different than one for a Pitbull. When I had V&H 2into2, it was just a flat bracket. What's there to weld? And even if it has an offset, you can bend it.
Yes you can bend it but again any additional forces placed on the material is going to cause stress and that stress is going to propagate into a broken part.
The K9 is a much larger bracket and would require extensive bending to make it fit right.
Believe me if I could just bend up a stainless bracket real quick and buff it to mirror and sell them I would. But I would be looking at upset customers, depending on how many miles they put on their bikes, in short order. Not to mention the liability side of the issue.
Not to long ago I was involved in a law suit, just the special witness side of it, where a guy was claiming that he lost control of his chopper because a truck crossed the center line slightly during a corner which caused him to have to lean and steer harder. When he leaned over he dragged his V&H pipes really hard. His lawyer claimed that the exhaust mounting bracket failed and that was what caused him to crash. They were suing for 25 million.
A lot of people don't understand what something like a chrome exhaust bracket can cost.
Of course if you make 1000 thousand of them the cost can be kept to a "reasonable" amount.
But to make "1"
The bracket must be acquired........................20-30
Now it has to be cleaned up and buffed...........50-75
Now chromed..............................................50
Never mind all the running around to take it to the chromer e.t.c.
BadBrad
2005 Pitbull
You're dealing with all makes and models, so your knowledge of what those different models need far surpasses mine. Rocky's '03 Mastiff (LSD) and my '05 Pitbull (RSD) both took a flat bracket with those pipes. They both came with the bikes and are chrome steel. But to replace either of those would be a simple task. My knowledge is limited and my brain is simple.
