francoblay1
The Spaniard
depends on your depth perception and if you're in the US or in Spain as well...need to consider all the VARIABLES.....hahaha
Just flip it over or does that make the tire tread backwards? Might have to swap the hubs because for a fact brake rotor is on the left.The guy that done it put it on the right. Does it make a big difference
Make sure the tire tread is facing the right way, and the brake rotor goes on the left from behind the bike....if the tread is wrong he put it on backwards....the manual I pasted will show you a break down of it....Just flip it over or does that make the tire tread backwards? Might have to swap the hubs because for a fact brake rotor is on the left.
I'd have to see the rims but also might make the rim design backwards? Take a picture?
Front stem is in the middle anyways so no biggieFront tire doesn't matter, when can go on either way, just make sure tread is correct.
Those rims don't matter design is the same both ways just make sure tread rolls the right way. In your pic the arrow on the tire should go clockwise to the left
Haha yea on those both my bikes there is a pretty distinct way the rims need to roll. And those shark fins are tapered so the metal is thinner at the smaller portion of the fin and runs thick too end so it would look ass backwards. Although you are probably right most people wouldn't even notice..@Th3InfamousI, you seem a tad OCD, I mean CDO about your little shark fins my brotha, my front pitchforks run the same either way-going to hell or coming back....
You did bring up a valid point-DEPENDS on the RIMS!!!!
Yea I get that. That's why I said it doesn't matter after I saw your styleMy rims are different than yours
