Bottom right of 2nd pic ShannonCan't see it, that's the ignition module.
Sent from my SAMSUNG-SM-N910A using Tapatalk
which wires? Probably other guy has same issue.Got it figure out ,
The wires were reversed ..
I am a dumbass...
Bright side I now have 3 daymaker headlights
I had the wires messed up from docs headlight harness, I had a pigtail from an old headlight that I pulled out of my spare parts drawer and used it to switch the wires around. As soon as I pulled it out and looked at my setup , I recognized that the wires were not installed properly. Switched them around and sure enough that thing lights up my garage.which wires? Probably other guy has same issue.
Well you got enough to last you 20 years now.
It was weird they didnt work for you I've had them in all units available personally no joke. Well except original ehc. Docs, WP, Rip and axles
Glad the problem is solved!I had the wires messed up from docs headlight harness, I had a pigtail from an old headlight that I pulled out of my spare parts drawer and used it to switch the wires around. As soon as I pulled it out and looked at my setup , I recognized that the wires were not installed properly. Switched them around and sure enough that thing lights up my garage.
The headlight was a little loose in the adjure bucket, I used electrical tape around the black trim of the headlight and put about 3 layers around it, the headlight is fully seated and does not move inside the bucket.
Thanks and the light is awesome especially for the price..
Check your wires coming from the headlight harness, I found that I had them installed into the plug wrong and that was my issue. Yellow wire is on top, white wire on the left from the front and ground is on the rightMy replacement is not due until tomorrow . Probably wont get to until Monday and if it doesnt work I guess I will buy the one LED Bulb that shovelheadkicker has for $40
Yea, he and I can see the fuse. He'll have to take the side cover off to see the EHC.Bottom right of 2nd pic Shannon
Yea, those bolts you see just inside the frame. 7/16'' socket.Do the side covers have to come off?
I did not, ShitGlad the problem is solved!
Loose? You kept the wave ring in the adjure, right? Mine is tight as hell in the adjure.
Which side should the EHC be on?Yea, he and I can see the fuse. He'll have to take the side cover off to see the EHC.
Right side.Which side should the EHC be on?
