engine shuts off,??
mark6747
engine shuts off,?? PROBLEM HAS BEEN SOLVED, THANKS EVERYONE,
after washing my bike i let it idle for about 10-min, then the RPMs start to come down then shuts off, can it be loading up, or is it doing this because it may be overheating,??:confused::confused::confused: PROBLEM HAS BEEN SOLVED, CARB. NEEDED TO BE AJUSTED, BROUGHT IT TO BIG DOG OF TAMPA FL. IS WAS RUNNING RICH, THEY SET IT BACK TO FACTORY SETTING,!! I WOULD LIKE TO THANK EVERYONE FOR HELPING ME OUT,, THIS IS AN AWESOME WEB SITE,,,:whoop::whoop::whoop:
bigdogtech01
Did it do this one time? will the bike not run now? We need a bit more info from you.
Post make and model, year, more description of the problem and what it is or is not doing.
Thanks:cheers:
mark6747
there was no water under the seat at all, after it colld down a bit it started fine and ran beautyful, i let it run a little over 5-min again and it ran great this time, i am thinking that i let it idle a little to long last time and it loaded up with fuel because when i gased it up it pop through the carb and it smelled like raw gas, i dont think they should just sit at an idle for a long period of time, like i said when it shut off the first i had it sitting for a time and you can here the RPMs slowly coming down and then she just stalled, other then that she runs very strong down the road, WHAT DO YOU GUYS THINK????
THANKS
MARK
THANKS
MARK
You using the enrichener to start it?
stinger1
These engines are air cooled, you should never run it standing still for that length of time. you will have seizure proplems !!
mark6747
never, i pump the throttle once, i idle once again for five-min this time, it ran fine, i think 10-min might have been a little long for idling,
V
If you're doing that you should goose the throttle a bit now and then also make sure that it doesn't idle down to low where the tach is flashing as this indictes low oil pressure. also as mentioned air cooled should not be idled to long. I did just crank mine up last week because I forgot what it sounded like and ran it for about 15 min but it was in the high 30's :rant:
Little-Boo
When I work on my dog that requires it to be running I use a floor fan and aim it at the right front so it can hit the engine, exhaust and carb area. Plus it also hits the oil air cooler. However I never have had to idle for more than 5 minutes at the longest.
Carlos :whoop:
Banned
Carlos :whoop:
:2thumbs: I use a comercial type air mover fan on mine to.. if it needs to run for very long..
bigdogtech01
THANKS
MARK
How many miles you have on that '04? It might need a new Fuel/Air screw. They tend to wear out after time, getting a slight grove in the tapered end of the needle. this will cause the motor to run too rich. I'm sure there is a thread on this on here and how to readjust it. if you can't find it, PM me and I'll go over it with you.
Also like others have said, make sure your idle is set around 900-950 RPM. If it is lower than that is may load up and stall.
Does it seem to run fine otherwise? It is possible to have an intake leak. While you are checking the fuel screw, also check to make sure the rubber plug on the carb intake vacuum nipple is still good and not all dry rotted.
mark6747
my problem was solved,, it was what i thought it was, she was running rich,, brought it to big dog of tampa fl. and had the carb ajusted,, i would like to thank everyone for the help,!!!!
KEEP YOUR HEAD IN THE WIND AND RIDE SAFE,
THANKS AGAIN
MARK
