engine drive hub
ab37752
I have a primary leak .I,m having trouble getting the engine hub/sprocket nut off. is it right hand or left hand threads. thanks for any help::bang:
RRRUFF
That nut may have locktite on so heat it up good then try to break it loose. Avoid using an impact wrench if you can, that could damage the magnets inside the flywheel.
HotRod
When going back together I smear wheel bearing grease on the gasket seals it right up.
