Electrical
I have a electrial problem. I replaced the wiring system, with the Wires Plus System last winter. This weekend went riding and noticed no headlight and driving lights. But I had brake lights and blinkers. Could it be starter switch or power supply? Start bike and 3 green lights on pwer supply then lights go and one of the lights turns red.
Thanks
bdmridgeback
Low Down Chop Shop
Red light means that breaker tripped. So whatever is on that circuit is shorted out and has tripped the internal breaker. Check headlight bulb or harness, or harness to one of the running lights may be shorted at the rear fender.
Unplug the small factory bdm jst connector at the rear fender and see if that clears it up.
