Thanks for your help. just got back from auto parts store with di electric grease. will possibly tackle this evening or the weekend. this was my next step to trace the ignition wire all the way back to ecu and re pack all connection with di electric grease including the two black connectors going into ecu. I will be careful to watch the pins. know about this a lot from my work dealing with EPROM software chips on logic boards. pins are tiny and bend just by looking at them. battry right now has 12.83 volts on it and I am working outside right next to the bike today so I can watch it close to see if lights come on today for any reason. I will check battery voltage several times today and see if im losing voltage because of a current draw on the system. I just know everyone is saying its the ecu and it mightbe, im not ruling that out for sure, but im not having any of the other symptoms most people are having on here with bad ecu's. they seem to have hi/lo beam problems, no blinkers, bike wont crank, bike wont shut off, all ecu lights are lit up. im not having any of those issues! just a ghost turning my key on even if there wasn't an ignition on the bike to pit a key in. the lights are not coming on as much as they were on sunday, maybe if there was some water in the connections it is almost gone, but will still check and clean and re apply di electric grease to my connections. Thanks to everyone for the help, this site is a major help and to see what other issues people are having. I guess we are all learning from each other.
