Axel
Hi Savage 1,
You can use the M-Unit or the B-Box or any other control box if you change the rearlight insert and add a relay for the starter solenoid and the deco valves. I attach a schema with my B-Box (The M-Unit will get the same connections in your bike) and the actual schematic for the new EHC what should be available in April 2022 ( ...if I get the required high side switches from Texas Instruments in time ) . Just feel free to send me a mail at info@elektronikbox.de if you need further infos of the wiring or the PIC C - software for your own project. It´s no rocket science anyway. I also have made an adapter for the 2 connectors what allow to use the original harness w/o the need to cut the connectors at the harness. However, the adapter in connection with a control box is not a perfect solution but it helps to bring your bike on the road earlier.
I hope it helps. I wish you all a nice Christmas time !
All the best!
Axel
All the best!
Axel
