EHC wiring schematic
Axel
Hi Savage 1,
You can use the M-Unit or the B-Box or any other control box if you change the rearlight insert and add a relay for the starter solenoid and the deco valves. I attach a schema with my B-Box (The M-Unit will get the same connections in your bike) and the actual schematic for the new EHC what should be available in April 2022 ( ...if I get the required high side switches from Texas Instruments in time ) . Just feel free to send me a mail at info@elektronikbox.de if you need further infos of the wiring or the PIC C - software for your own project. It´s no rocket science anyway. I also have made an adapter for the 2 connectors what allow to use the original harness w/o the need to cut the connectors at the harness. However, the adapter in connection with a control box is not a perfect solution but it helps to bring your bike on the road earlier.
I hope it helps. I wish you all a nice Christmas time !
All the best!
Axel
Savage 1
Thank you very much sir! Greatly appreciate the help!
I prefer making my own repairs, it helps to know how things work.
I'll hold on to the email address in case I need the new parts in the spring.
Merry Christmas to you as well!
