EHC is history
Ragetti
I changed the EHC with the motogagdet m-unit.
My solutions was to cut no wires, so I used 2 d-sub -connector with 50pins and built a new wiring harness between the 2 connector A and B and the m-unit.
The only problem was the space for the connectors, because they are big, but it works perfect.
The horn is now under the battery in the free space, the fuse is on the right side , and the relay for the horn is away, the m-unit didn´t use it.
Greetings from Germany
Ragetti
yes it has it own´s alarm,
you can vote the turn function (10, 20, or 30 times)
there is now only the start button not more to press off and run-button
Rolf
Guillaume
Love is the feelingtyou get when you like something as much as your Dog
If I understand it right you don,t has your EHC anymore ,Well that is great and what is the cost off it to change that out .:2thumbs::cheers:
Axel
Hi Rolf,
Great Idea, I think, I´ll make some clones with potted D-sub connectors and my D-Box (http://www.elektronikbox.de/ebox_d_uk.xhtml)
All the best!
Axel
