EHC Cross model compatibility
zenBD
Anyone know if an EHC from a carb pitbull will work with a K9? Are all models from a given year compatible as long as they are carb to carb or EFI to EFI?
zenBD
That's what I was thinking... Doesn't it say the year & carb (or EFI) on the side of it?
Rottweiler
Damn good Question? I have a 2004 chopper and trying to use a carb 2007 EHC on it? Some times it works most of the time no. It has a adapter plate from the two plug to one plug for 2004. Trying to figure out if I still have a wiring problem or is the 2007 EHC looking for something not on my bike? :bang: From the wiring prints not much difference except compression release grounds? :loony:
According to BDM you cannot interchange the carb and EFI EHCs but if I'm not mistaken a couple of members here indicate they have done it successfully.
You should be able to interchange any carb EHC though from 05 forward.
Prior to 05 there are a few adapter boards floating around which I presume, if built correctly, would allow you to use a newer carb EFI on an 04.
kickstart
There were several (Service Bulletins, Safety Recalls and Service information letters) about EHC's
23JUN2006 SB-1078A RED URGENT EHC CONTACT IMPROVEMENT
21AUG2006 06V-305 SAFETY RECALL EHC P/N 170-000001-00 CLEAR POTTING ONLY
07Dec2007 SB-1098A RED URGENT Firmware update for EFI
SIL-0001 Current EHC information sheet 02Feb07
SIL 0002 EHC Communication issues 02FEB07
SIL 0005 EHC software functions 07DEC 07
I have some of these, anyone need any let me know.
Brew
I can't vouch for different year models, but yes I'm running an EFI EHC on my carb bike. The EHC came out of a 2008 K-9 and it's in my 2008 Mastiff...
Also hear tale that a carb model EHC won't work in an EFI bike, I believe this to be true...
Rottweiler
Yes I believe same year should work. My experience with a 2004 and a 2007 did not work. Got another 2004 and bingo back in business.
zenBD
Good information here... Might have saved me from blowing a few hundred bucks... I was looking at one on eBay that said it was 04-08 compatible, but sounds to me like it has to be your year or nothing.
