EFI Malfunction (light On)
Does anyone know what would be causing the EFI malfunction light to periodically come on. When it does come on, it runs rough. Any help would be most appreciated.
I'll start you off with some manuals, I'm not the expert on this, just alittle bit. someone will get to you soon
Thanks Shannon. By the way, i guess I should be receiving my paint saver in a couple days that you made for me. Thanks for the quick job.
Marky-Marc
That light on your EFI could be telling you that you've lost your "ideal" fuel/air ratio that the CLEFI is trying to maintain, it'll run rough and then go back to normal. What octane of fuel have you been using? Clean your fuel system. Run a couple caps of seaf-foam through each tank of gas.....once your fuel system is cleaned and it potentially solves your issue, put like a 30 micron fuel filter on.....
Thanks Mark. I will try that before taking to shop. Appreciate your quick response. Very helpful videos by the way. Good job!
When you pull the injectors to clean them, you can use a small square 9volt battery to open them. Don't use the 12 volt on the bike, you will burn them up.
Jwooky
The only way to know is to set up Pro Tune on a laptop and check the fault.
Otherwise you will just be guessing.
