Dumb question, maybe, but....
knothead
Second Chance Customs
No more than 8 foot pounds of torque or you will snap the bolt....put a something over the gear like a couple of rags so not to scuff it up with pliers
macs13
When perusing the threads, I thought I saw that it was to be torqued up to 60lbs. Secondarily, to get a socket on it, would I have to bend up the keeper tab on the outer washer?
Jersey Big Mike
100K mile club
knothead
Yes you have to bend up the tab to get a socket on it....just use a flat head screwdriver and a small hammer and gently bend the tab up....
No sir its just a 1/4 20 bolt.... 6 to 8 foot pounds or 76 inch pounds.....
Jersey Big Mike
100K mile club
No sir its just a 1/4 20 bolt.... 5 to 8 foot poundz or 76 inch pounds.....
and 5 ft/lbs is 60 in/lbs which may have been where you got the 60 from.
Don't you have to bend the tab DOWN so you can get a socket on it and UP to lock it against the side of the bolt head?
macs13
New question for all of you knowledgeable fellas. What, if anything, can be done about the REALLY long stops at the gas station? I'm not talking about the frozen burritos either. It takes forever to fill up the pitbull. The split tanks where only one has a filler, so I have to wait for it to slowly trickle to the left hand tank.
I'd love to know what you guys have figured out.... I'm planning on doing a solo Iron Butt Association ride with her soon and it would be great to not have to stop for 20 minutes at every fill-up.
Uh, both caps are made to come off. One is righty tighty the other is righty loosy.
macs13
Well that makes me feel smart. Although, I just went to the garage and the left side isn't budging. I definitely always thought it was a dummy cap. I'm guessing it's stuck in there now since it's never been removed.
chubs
Sounds like someone may have tried to unscrew the left cap and succeeded in making it even tighter. You might try using one of those rubber jar opener things that women use in the kitchen, and turn the cap in the direction that normally would tighten one. (it worked for me )
Or a rubber strap wrench..... If you have the OG Landmark caps, its prolly the swelled plastic gas cap threads that are locking it in? They swell from the ethanol in the gas. Once out, a little sanding on them will help. Or new caps?
Mickmorris
Well Known Member
Just remember that the left tank cap unscrews to the right. I posted a picture of the old style (r)& the new (l). When you get it out you can order the new style from BigDog or sand it down like HMAN said. My old ones looked like shit so they had to be replaced. FD5D3B6A-7159-473F-A492-43CE81D073C6.jpeg8ECF7D02-95DB-490F-BC2D-3F5227C75072.jpeg
