Dual coils
ringo
When you consider the need to derate due to the high heat conditions, I would suggest 18 AWG as a minimum. Should be over kill from a pure ampacity standpoint.
Diesel Dan
Dude I would HIGHLY recommend 12 guage wire,solder,crimp and heatshrink ALL CONNECTIONS,and use dielectric grease, AND KEEP your wiring as short as possible to prevent current loss,do that and you will be fine!!!!!!!!!
DRBarnhart
Insert title here...
What's the wire gauge coming out of the ignition module, 18? That's all you need. All you get with a bigger wire is more to hide.
And due to vibration I would crimp the ends.
Dennis
