dantep
Gone over the service your bike pdf many times and done a ton of searches. need a little help. The question I have is on the drain plug. Is it the actual long tube that goes straight down from the oil tank on the right side, if so do you take the tube off then undo some sort of drain plug and then put the tube back on or is there something at the end of the tube itself that I undo so the oil will just straight drain out of the tube. Any help would be great, thanks
