Does your Dog wobble?
ringo
Apparently mine does. Passed a work truck today, I dunno-know, probably in the 80-85 MPH range, and Whoa!, the front end gets in this wobble, it quickly settled out, but it was kinda unsettling. Maybe I set it up with something I did, not being smooth enough with my control movements or something, but this is the first bike I've ever had this happen with. I guess she's a little top heavy.
BBChopper
Supports 2 Disabled Vets
My Chopper is lighter than the K9, never any issues like that! Pass pleny on SEMI's on 95 at 95+....
Cshores
You need to check that out pronto. No reason for a motorcycle to ever wobble...
Always pay attention to those signals. The only thing it could be was a strong cross wind when you passed the truck....but I would still check the bike out.
ringo
good idea's. IM ashamed to admit I have not checked tire pressures. I can see the front is not low but that fat rear with no sidewall could be low and not obviously show. I'll go check um.
I've never done a fall away measurement but looking at in the manual it seems straight forward.
shovelcowboy
It could have been wind created from the truck. Ride the same road at the same speed again and if no wobble, then I would blame the truck and wind and not the bike.
I have a Harley with a windshield and passing trucks will sometimes create a little wobble.
Shovelcowboy
Never had a problem on 20 i do on 79 left lane with said. I would be checking the triple tree and air presser and front axle bolt if it is all good take the run one more time and see what it does it might have just been wind
ringo
Both tires were down about 10-12 PSI. I inflated to spec F-40 R-42 PSI
Took her out for a spin up to nearly 100 and nothing, however, if I purposely induce a wag it goes about 3 or 4 cycles before it settles out. So took my KLR out it does it as well but settles out quicker.
BBChopper
RIP!
ringo
induce the wobble youself and see if the bike goes thru a few cycles before settling down like mine does. This in itself may not be unusual, but it does it very easily.
