Documenting the tear down rebuild
As you all read cracked my swing arm and rear fender! This prompted me to do a complete tear down and rebuild way earlier than I wanted to. I am going to document this from start to finish. Just like la dog ! So I will 1 focus a lot of attention on getting my pit bull finished to ride while the bbc sled is down. Mods I am thinking about doing are!
1. Transmission rebuild Jon or Andrew May get some calls.
2. Engine bored and want to remove the ca restrictions.
3. Frame re powder coated pending any more cracks
4. Engine polished and diamond cut
5. New rear fender may put the Athena rear fender on with new paint
That's really all for now! I am leaving on another "trip" Sunday and will be out of the country for awhile! Time to go to work !!!!
Tonight I started the process and I assure u all no good wings in my garage
Day 2 done!
1 removed the oil tank
2. Loosened up the primary! I am having a hell of a time removing the clutch basket. This was easy on the Pitt.
Tomorrow I will remove the primary and hopefully the trans! I leave on Sunday for a month so I will post day 3 and be out for a bit
Another pic ! May need some help removing the clutch baskets. Do I need to remove the 1 15/16 nut on the right side to pull the basket ?
Brew
Day 2 done!
Btw my neighbor who is a foreigner and does no work on anything was giving me the third degree for always working on the bikes ??? I will vent and say no more but happy 4th all
I wouldn't think so! You should be able to pull it off...
I thought so but it is on there tight..... I removed the entire primary on the pibull and it was easy.. not sure why but I decided to shut it down today and try aging tomorrow.. this sucks that I am doing this too early once the pit bull is running it will be a good rebuild... Thanks brew
TimNY
Paul
Your doing way to much work on
these bikes to be working on the floor !
Treat yourself , check local craigs list .
Buy a lift .
Swing arm removed still having a hell of a time removing the clutch basket and inner primary. Will tackle that once I get back.
The clutch basket will not budge. It has about approximately a 1/4" of movement but seems to get hung up? I looked and nothing that I can see is stopping it. It appears to hang up on the splines from the transmission shaft ?
I am thinking of taking my heat gun to it to see if there may be some loctite holding it on.
hub nut may have flared the splines a little? looks like that would be about 1/8th inch.
So has anyone ever had this happen? I am looking at using a crowbar and mallet with some rags to try and knock it off the splines. Just need to be careful not to damage the trans or the primary back plate.
JeffM
Bud make a little plate with 2 holes that go across the main shaft and a couple pieces of threaded rod to go into the clutch basket, wind on some nuts and jack it off. Use your main shaft nut to protect the thread.
