Michael rogers
I have an 08 mastiff my right directional front and back dont work i was trying to figure out if its the switch
Sent from my SM-N960U using Tapatalk
Could be the hand control switch...does everything else work on that right hand control correctly? I mean it could be a short or the switch.[/QUOTE]I have an 08 mastiff my right directional front and back dont work i was trying to figure out if its the switch
[/QUOTE]Everything works on the switch accept the directionalCould be the hand control switch...does everything else work on that right hand control correctly? I mean it could be a short or the switch.
It could be the bubble on the pcb board. You can carefully peel it up and clean the contact. It happened to my horn button once.[/QUOTE]Thanks ill have to check it outEverything works on the switch accept the directional
Thanks ill have to check it outIt could be the bubble on the pcb board. You can carefully peel it up and clean the contact. It happened to my horn button once.
