Developed a bad shudder....
It appears that I have developed a problem. It started about 50 miles ago when I began to notice a vibration on decel. I could accelerate and it would disappear, but it became worse as time went by. At first I thought it was because the rear tire was cold and had a "flat" spot from sitting and it would kinda go away when it warmed up abit from riding. On the way home from work today, it got real bad and I thought maybe I had a broken clutch basket. When I got home, I put it on the lift, raised the tires off the ground and cranked er' up. In first gear with no throttle, everything was fine for a few moments, then this horrible shudder started. The whole bike would shake, then it would go away, then it would start again, then disappear again. WTF?
I checked the rear tire/wheel and final belt, found no problems, every tight. Then I pulled the outter primary cover expecting to find chain, basket or front sprocket problems. Nothing. Everything tight. No metal or shavings in the fluid. What's next? Tranny? Anybody experenced this? I have not disassembled the clutch yet, nor have I looked into the trans yet. Hopeing someone will stear me in the right direction....:confused:
Nomad2day
Longhair Redneck Geek
check your top motor mount
For sure do as Hoat said........Mine just came loose Saturday on a country cruise. Didn't have any tools with me so I just put my finger on the Allen head to keep it from loosening up more. I would of been hosed if the EFI cover side had fell off going down the road. Would rev it up so I could screw it in some. Talk about having one big ass cramp in my hand when I stopped at a friends house...
bdmridgeback
Low Down Chop Shop
When My top motor mount came loose, when I deceled I thought that damn thing was going to shake every part off it!!!
BINGO!!!!!!
Hoat hit the nail on the head!!
The two smaller ones were loose, got em' tightened up good.
My only question now is, why did I not ask here first...
Oh well, live and learn.
Hoat, if ya'll ever get around N.E. GA, gimme a shout, I got a kegerator on the back porch, and we'll have a big time!
:cheers: :cheers: :cheers:
Thanks man!
(You too Neil!) Thanks!!:whoop:
Yes, I do gotta love the easy fixes, and the great help I get here.
Thanks again for the help, and thanks for the linkie, Ray...
:cheers: :whoop: :cheers: :whoop: :cheers: :2thumbs:
txchopperguy
I always know when mine does that cuz the tank starts to vibrate really bad...crank em back down and it goes away.
superfly
Ride it like you stole it
MIne did the same thing a few months back. I was lucky enough to find it and then I read on the board the easy fix..
KnotSo
Admin
Coming back from Kali this summer my scoot developed a "wandering" (quickly darting one way or the other) tendency that was there for the time thru N Cal, Oregon and up to the house. It was also there for a ride to work, it came and went. Then it disappeared and has not returned. I was white knuckeling it there for a few days. Never did discover what it was, but will say it made riding above 85mph very interesting.
Good luck on tracking down this issue and let us know what you discover it was causing this shudder.
See ya
