Detonation and Back-firing
yingerg
Hello, My bike just started detonating when i ecellerate and back-firing on decell. and on idel its idling fast when warm. about 1200 rpm. does anybody know what could be causing this problem?:bang: It was running fine but now it runs like this all the time. Thanks for you help.:flag:
2004BC
FREEDOM!!!
Completely just guessing here but possible intake manifold leak? :cheers:
2004BC
FREEDOM!!!
That is a good question and I would wait for a more professional answer than what I have done in the past which is:
1 - With bike off grab carb and push gently up and down and see if it's loose.
2 - Tighten all bolts on intake manifold band clamps, start bike and observe results.
3 - Spray carb cleaner, starter fluid, etc onto edges of intake manifold band clamps gently and carefully while bike is idling to see if there are any changes in rpm. If so, leak, but be careful with flammable spray fluids for mess and possible explosions.
I would try 1 & 2 but not 3 until you get some other responses. :cheers:
Dakotabos
You may want to check the vacum port on the carb or the Manifold. I found my cap blown apart and bike was running but now as smooth as usual. This is what mine looks like
Those top black nipples are little caps. Sorry now that I said nipples I might have to put this thread in the alley. :cheers:
Dakotabos
Awww Mad Dog you had to go THERE? Damn :bang:
HA
I knew I should have picked a different word with you guys
yingerg
Thanks, I been racking my brain on the internet trying to find out what those nipples, i mean caps......... are. because one of them must of blow off. were do you find these nipples. or can you just plug em with anything?
Dakotabos
Get the caps at Autozone or auto parts store and get zip ties. Put the cap on and zip tie them. They come is different sizes just like nipples:roll::roll::roll:
Glad your issue is fixed after you do that :cheers:
Chippy Chad
You may want to call them vacuum caps when you get to the parts store, they are cheap and usually come in an assortment of sizes.
BADOG
THIRD NIPPLE LOOKS LIKE IT WOULD BE PRETTY EASY TO FOOT FEED THE PUPS!!
WOULDN'T LOSE TOO MUCH SLEEP, COULD FEED AND NAP AT SAME TIME.
