Took my bike for a ride the other day and it ran great. Got home put it in neutral and laid it on the kickstand and right then it started running bad so I shut it down and started investigating. I found the plug wires were rubbing on the coil bracket and worn through the insulation on the back cylinder which I determined was not firing. I checked the spark by pulling the plugs and turning it over with them against the head and I have spark. I replaced the wires with twisted wires and new ngk plugs but the rear cylinder is still dead and it kinda looked like it was blowing back through the carb a bit. Could it be a bad ignition module? Any thoughts? ? Thanks
