Dakota Digital Issie
Dawgboy
Anyone with a Dakota digital notice the digits on the display appear to float around? At about 3000 rpm my display appears as if the digits are actually floating around a bit. Don't know how else to describe it...
avdhunter
Yup I got a video of it I will try to post...... but I think it was my eyeballs and the camera jumpin around at 95 mph!!!!:D
Daddycool
without seeing it for sure, I'd step out on a limb and say it may be a visual illusion. I sometimes see it on computer screens at work with vibrations.
Mad Dog
ValueTeck Enterprises
If you guys think there is a bonified issue with the readout don't hesitate to call Dakota's Tech. Support. 1-800-593-4160 They will want to know about it. I'm kinda with Marc on this though. Sometimes vibrations can cause visual illusions. Keep me posted.
chacha
Chaff Your EHC!!
You'll find it's the vibrations and at certain RPMs (harmonics) the illusion is more noticeable with anything using LEDS. At 4800 when not moving, my Rear LED strip looks like it's going to fly off the bike....
Magoo
Dog Locked
I had the same issue with mine and found BD made a replacement speedo mount that is wider and cuts down on the shaking, installed it and problem solved.:whoop:
pknowles
RETIRED
If the 07 Bulldog came with a dakota speedometer i had the same problem. Sent it back to the shop and the bezel ring?? was loose. Got it back and the illusion went away.
