SMCT
I had noticed on many Big Dog applications, that they incorporate a "one way valve" so the engine can vent it's pressures out but not allow any air in from the atmosphere. I stumbled on this here below:
P.S. I guess you can edit the body of the post but not the title? Trying to correct the title spelling..wtf...lol"If installing a hose in the lower case breather location,
DO NOT use a hose by itself. Lower engine
case breather hose must be fitted with S&S #50-
8122 one-way valve. If the upper rear head
breather location is also used, it also must have a
one way valve installed. In either location, white
end of valve faces engine.
SSW+ engines breathe differently than Evolution
style engines. Not installing the one-way valve
will result in a direct engine vacuum leak, affecting
performance."
