05 old dog
ok. installing 600 cam and new roller lifters, quickie pushrods with new S&S entire topend...first does anything change on pushrod adjustment with brand new lifters. just put assembly lube on and adjust? or do i let them sit in new motor oil, install and adjust? also have cylinders and heads off to be diamond cut, gonna run hone thru cylinders and install new rings and piston clips...will mobil synthetic be ok for breakin or do i go back to dino oil for breakin? just to let you know...14,000 miles and cylinders still have good crosshatch in them...few very small vertical marks that you can see but not feel...lots of carbon on piston tops...sachs will be working over heads and carb.
