PHATASS
I sent my transmission out for rebuild a few months back due to a worn main bearing at 18K miles and a cracked case caused by a hydraulic press malfunction. After getting the trans back with the new case, I’ve been having a problem with the left countershaft seal slowly leaking after short rides. Other than the leak, the transmission shifts flawlessly. I’ve had the transmission out 3 times double checking alignment, shimming, and any other factors that may cause the leak and can’t find anything wrong. I also noticed a vibration/shake throughout the bike only at higher rpms when engine braking and just before up-shifting in the lower gears but can eliminate the vibration/shake completely by pulling in the clutch handle. I’ve been through every component in the primary, transmission, torqued motor mounts and replaced the countershaft seal but still having the same issue with vibration and leak. The only other thing I can think of is an out-of-round condition where the countershaft bearing fits into the case. Any suggestions would be greatly appreciated.
