Cool Coil Bracket
cvegmond
I've seen a number of Big Dogs on the forum with the same top engine mount with coil bracket. The coils are mounted in a v-shape where you can see them. The bracket is a pointy tribal looking aluminum and I need it.
Anyone know who makes it?
Thanks.
cvegmond
Gothic Coil Bracket
vulcan motor works
Yes, this website has the best prices on this bracket.
Do we need to buy the top motor mount as well?
Do we need to buy the spacer to clear the fins?
Can the stock spark cables be reused?
Will the stock ignition switch work with these Gothic Spiked Coil Brackets?
Thanks.
Iman
to answer your questions, yes you can use the same ignition. motor mount comes with spacer(yes you need it) Motor mount number 3141 and 3ohm coils number 4239. you can use the same spark plugs wires. i ordered taylor thundervolt from sumax. You can custom order the length you need
Iman
ign switch fits perfectly!!! you can paint your coils to match the color of your bike. They will need to be painted!!!
